kosPap
greetings all! I hope you are having a good time this season...
(and I hope it is the correct subforum I am posting)
So...
How about a MC-E connected 2S2P?
From what I can tell one goes for 1400mA output, 2xVf of the LED and a two cell Li-Ion or equivalent battery combination.
The big question is can it work with a resistor??
I used the Firestorm and LED Pro resistor calculators and from an input of 8.4 and Vin 3.6 (actually 7.2V for this connection) I should be using a resistor at 0.85 Ohms (correct?)
(though the calculator said 8.5 Ohms)
Which is big and my bigger problem is
How do I calculate the watt rating? Should I be using the W=I^2R? that would be W=1.4^2x0.85 Correct?
Than amkes 1.6666 watts that is not bad for the situation...
Now If I only knew that kinda of resistir dimensions? Can it fit inside a 17mm board flashligh pill?
Feel free to correct my math, please, Kostas
ETA: Seems that i will have to go with a higher Vf bin, or else that excess voltage will have to be spent on the resistor...
So...
