Elektrolumens EDC P7 left ~2.8A, Ultrafire Q5 14500 right ~1A.
Left L-mini 1*18650 Q5 ~1A, right MTE 5 mode 1*18650 P7 ~2A.
From jtr1962's testing of LEDs at 1A.
Q5
237 lumens at 1000 mA (*1) & 288 lumens at 1400 mA
R2 270 lumens at 1000 mA & 335 lumens at 1400 mA
P7 328 lumens at 1000 mA &
440 lumens at 1400 mA (*2) &
581 lumens at 2000 mA (*3) &
741 lumens at 2800 mA (*4) (jtr1962 has not tested any MCEs yet but I figure The MCE & P7 is fairly close as they are both 4*late bin XRE dies.)
http://www.candlepowerforums.com/vb/showpost.php?p=2170040&postcount=141
http://www.candlepowerforums.com/vb/showpost.php?p=2412997&postcount=158
http://www.candlepowerforums.com/vb/showpost.php?p=2668288&postcount=229
*1) 237 lumens Estimated output of Trustfire TR-801 & Shining Neam L-mini & Ultrafire C3/14500.
*2) 440 lumens Estimated output of Trustfire TR-C2.
*1) 581 lumens Estimated output of MTE 5 mode P7.
*1) 741 lumens Estimated output of Elektrolumens EDC-P7.
Looking at the pictures of the Trustfire TR-C2 I am concerned at heat removal from the LED. With heat having long thermal paths through the front of the reflector and round and round the springs. I do not think the LED can be driven hard or LED life would be short. I would recommend using Low normally and go to High only when necessary on burst. Unfortunate the modes are High>Low>Strobe.
Hi (2800mA, 430LM) > Lo (1000mA, 100LM) > Strobe (1500mA, 200LM) is interesting.
Trustfire is claiming 2.8A on High yet only 430 instead of the normal '900 lumens'. From jtr1962's testing of P7s 440 lumens comes from 1400mA.
Trustfire is claiming 1A on Low yet only 100 lumens. From jtr1962's testing of P7s 114 lumens comes from 320mA.
I have a sneaking suspicion Trustfire is under-driving the LED to avoid heat problems and just claiming 2800 mA because people won't buy a P7/MCE light unless they see 2800 mA.
So a Q5 light is ~1/2 the brightness of the TR-C2 but with a better focussed beam. Unless you need lots of floody light I would stay with a small Q5 light like the TrustFire TR-801 or Shining Beam's L-mini. These lights are another 5mm narrower than the TR-C2.
Note there are problems fitting protected batteries into some L-minis.
Note also I am using LED lumens throughout this post.
