mc-e reflector, lens question
videoman
I would like to reduce the beam angle to approx half of the bare emitter in a non-flashlight setup. I am looking at optics and reflectors as well as aspherics. two MC-E's placed side by side with 1 1/2" between their centres. The beam I am looking for is around 60 degrees from side to side with eveness of illumination and as little hot spot center as possible. Also the max diameter is 1 inch to fit the lenses in. What would be the best to use regardless of price? Thanks
Thanks Vaka, that's exactly what I need especially the 30X60 wide field one. They will fit precicely in my fixture without any modification. 2 questions though. Where do I go buy them and can these also be used with the XPG's. Thanks a lot.
I'm not a good adviser for byuing things, just look at my location: Moscow, Russia :)
For using them with XP-G you'll have to modify the holders.
By the way, there are many other optics manufacturers: CARCLO, LEDIL, KHATOD, LISA...
