kenster
The Mcr17XR doesn`t look like a good reflector for a KI-LE Cree mod but I`ll bet a Dremel can help trim it to fit OK.
Since it fits in the head the diameter of the top part of the Mcr17XR is fine but the diameter of the ring below needs to be trimmed down the same as the KI`s reflector so it will fit inside the LE.
Trick with not having a Lathe to trim this and using a Dremel instead is getting it round and an even amount removed all the way around. The reflector slides snugly inside the LE Can which screws into the head and trim it crooked so it slides in off center........
We will see how well I did in a minute?
With the reflectors sitting on thier Luxeon and Cree emitters checking for the correct hieght (or length) is pretty easy to see without even measuring. But I measured anyway!
Just need to make sure the ring left at the top is the same thickness all the way around so it will push on the lens evenly for the Oring to seal well.
Hmmm...... Picture is looking in the head off center so you can`t tell how well I did with my Dremel work and those shadows make it even harder to tell. Oooop!
Is it centered or not???
We will have to wait for Sengoku to mod his KI-LE to Cree with this reflector since it is boxed and ready to ship.
Hehe!
Ray, the box needs an address so send me a PM!
