Russel
Yep, it was my poor test jig that caused the excessive voltage drop! :sigh:
The CBA II battery tester has a couple short leads of #13 wire (as I understand it) to a powerpole connector. I simply took a foot of red wire and a foot of black wire and soldered the powerpole connector on one end of each, stripped the insulation off of about a half inch of the other end of each wire an tinned the ends. Then clamped the tinned wire ends to the Eneloop with a big wooden clamp. Not pretty, but it worked well. Here is the result of battery number five, which tested exactly like battery number one with the previous test jig, tested at 1000ma and 2000ma.
Looks like my batteries are OK after all. :twothumbs And I learned a few things!
OK, If I understand things correctly:
(1.347v [static after test] - 1.298v [1000ma discharge]) / 1A = .049 Ohms
or about 50 milliohms.
Is this correct?
Is this correct?
