Mechanical push button
sch115
Hello to all! Does anybody know what type of this switch is? Seams like there is a couple of "rebranders" using it even on expensive lights like Big Blue. I tried to do some searching but even after hour spent on google I couldn't find any info where to get these. From what I understand this is mechanical sealed button with spring and orings, touching electronic switch underneath. The question is if this system could be replaced or modified...
Thanks for you help!
David
I'm looking for similar information!
If it helps, here is what they look like unscrewed (it can be done with long nosed pliers but it will scratch the plastic up).
They screw in with an o ring and have a membrane that presses the soldered switch.
https://photos.app.goo.gl/R8tPiLdtX4ebSR1EA
Mine is a cheap Chinese light, but I think they'll use similar switches. I have 2 lights, one uses a button/switch with 3 "pins" to screw it in and one has 4 pins.
I didn't take a picture of the actual button but I will do when they dry!
