MicroFire Patrol (W3NR) 35W HID
gopajti
Hungary
Hello guys, you know my english is not too good, but, I made some photos, and videos of my biggest and brightest flashlight, I hope you like it.
details:
35W bulb (3000h lifespan)
Color temp. 7000K
3500 lumens
Built-in Lithium-polymer battery (5000mAh) comes with charger (Input: 100-240V~50/60Hz, Output 13.3V, 1200mA) charging time about 6hrs
Runtime: 90 minutes
I don't know exactly how many lux, but MicroFire says 98000lux (2m!) or pro-light.jp measured 75000+lux (2m)
Size: 115mm (head), 323mm (length), 50mm (body)
Weight: 1350g
Very robust, excellent build quality and anodizing, absolutely no scratching, clean and smooth threads
All pics in higher res, here
http://indafoto.hu/autoart/microfire
Very nice! Microfire has always had a great design!
The big 4" SMO certainly helps the throw, 75-98K @ 2M translate to 300-400 klux @ 1 meter, ~ 40W Polarion kind of throw, very impressive
Thank you guys!
Fusion, Patrol comes with 7000K color temp. only. No 4300K or other version.
Other,
Optional accessories
- KN DC vehicle charger
- G2 Red filter, 600nm
- G2 Yellow filter, 450nm
- G2 Blue filter, 480nm
- G2 Green filter, 530nm
- G2 IR filter, 850nm
- G2 UV filter, 365nm
- G2 Protection sheath (Silicon rubber drop protection sheath)
Wow, nice looking and great performing! Thanks for posting. Now if they added a lower CCT option, I imagine there'd be a ton of interest.
Wilkey
This info is very interesting. I've been looking for a somewhat affordable light that would out-perform my SR-90. The Microfire would probably cost the better part of $500.00?
trgrhppy
Price in Europe, 459 EUR. This is full package, incl. charger and battery
battery: 145 EUR
bulb: 107.95 EUR
Yes. Unfortunately, MicroFire is a small manufacturer, this is the reason why expensive they flashlights. eg. The Pioneer III (SST-90 LED with lens system and active cooling) this flashlight more expensive than Patrol, but I think they made only 50pcs. I hope understand.
Nice job! I noticed your light doesnt have the "arc shield" that mine does,a black thing that covered the top of the HID bulb.Did you remove this? do you know what i am talking about?
