Microfire Raytheon G9000R (9pcs XM-L2 U2 + 4pcs IR LED)
gopajti
Hungary
Look at this guys :drool:
New Microfire searchlight coming soon,
I have one pic, but, as I know, this is not the final version. btw later, maybe I can share more, real life photos (from IWA show)
now, what I know,
- Use 9pcs XM-L2 U2 led + 4pcs IR LED
- Max output: 9000lm
- Peak beam intensity: 5000lux@15m or 0.76lux@1000m (real datas, measured in real life in outdoor (beach), real 1km distance. Not "ideal", laboratory numbers)
- Four separate battery units which is composed from 9 pieces of 18650 li-ion batteries. On full power, it can run for 3.5 hours. Every battery unit can be removed for less weight in case, that don't need long runtime.
Update (2015/03/18):
- Water resistant: IPX7
- Tint color: 5300K
- Final version will use "flat lens/dedomed LED"
- Dimensions: Bezel diam.: 160mm, Housing diam.: 147mm, Length 300mm
- Weight: 7.5kg (with all batteries)
- Modes: 9000lm 3.5h, 4000lm 8h, 500lm 55h, 9000lm tactical strob 7.2h + IR 3W 850nm
- NO PWM or other flickering!
- Estimated retail price 2500 USD
new photos form IWA, thanks to Světelný Guru
Update (2015/03/19):
"throwing up to 2500 meters"
"Mil standard connector"
"Remote control switch available"
"Applicable to helicopter, grenade launcher, heavy machine gun"
new photos, thanks to my friend Bela from lanternetactice.ro
kj2
The Netherlands
Re: Microfire Ratheyon G9000R (9pcs XM-L2 U2 + 4pcs IR LED)
Cool :D
But a odd shape for most of us ;)
jonwkng
Singapore
Cool :D
Pretty unique design. Looks like the 9 XM-L2s are sitting behind aspheric optics with the 4 IR emitters in the recesses between.
9x 18650 per battery pack - that's a heavy weight for sure. :eek:
gopajti
Hungary
first post updated, added new photos and name will be Raytheon (not Ratheyon)
G. Scott H.
Arizona
That would be my ideal edc light, but they neglected to put a decent pocket clip on it. What were they thinking? :laughing:
richbuff
Prescott Az
Don't forget: Remove the carrying handle; hold it without the handle, so that way, you can tell by feel if it is getting too hot. :)
Mr. Nobody
In the lab
The consumer demands, smaller, brighter lights. This is definitely the opposite. But still worth looking at and possibly purchasing.
G. Scott H.
Arizona
I wonder if it comes with a rail mount????
Looks like you could just take off the handle and dual-sided rail adapter and pop it right on. Imagine that thing hanging underneath the barrel of your AR-15. Probably zero recoil, but you'd only be able to shoulder it for 2 seconds before your arms gave out. :laughing:
G. Scott H.
Arizona
So it actually is designed with weapon mounting in mind (albeit not the shoulder-fired type I joked about above :laughing:). Interesting. 2500 meter throw is just awesome. Thanks for the updates.
