Peter Atwood
I apologize in advance for the total newbie questions but here goes....
I ordered three MicroPucks with Luxeon Stars from LED Supply yesterday. Once I have them in hand and can get accurate specs my buddy is going to machine bodies to drop them into. My question is, using aluminum for the casing, how do we hook these things up to make a circuit with a 123 lithium battery? Is there a way NOT to do it that will result in the thing being backwards so that we blow the LED?
Looking at my Arc LS I see that there is a drop of solder connecting the board to the casing. I assume that the negative end of the battery needs to contact the base of the casing then the positive contacts the base of the MicroPuck. Using a piece of foam similar to the Arc to keep contact away until the unit is tightened, is that all there is to it?
Thanks for bearing with me. Any advice would be MUCH appreciated!
