kosPap
Here is a drop-in mod for the legendary Anglehead Flashlight, the Fulton MX-991\U.
(My specimen was circa 1993 so please check for design changes if you go ahead with this mod yourselves. (There is a reference pic below)
Assembling The Drop-In
The main core is a reflector pill assembly found in DX, the sku 18073 - Aluminum Textured/OP Reflector with Copper Heatsink Base for Cree MC-E LED Emitters (41.5mm*35.1mm)
Eyeballing it, it seemed it would fit so for the price I gave it a go. Well it fits VERY well and tight....And it is a hefty thing! And though it is marked to be a MC-E reflector I tried it with an XR-E Q5 (old EZ900 die) and it has a Glorious tight beam!
And then I found a driver that is close, the 21mm - 1AA Boost Current Regulated 0.8V-3.3V 750mA Flashlight PCB - S008844 from Kaidomain.
Unfortunately it is only yesterday after a month of wait that the drivers were shipped, so in the meantime had to do with a piggyback driver and case. A rare P60 pill with a 16mm !!!!! driver socket and a DX 4382 2AA driver....
I had to make an isolator of the reflector bottom and here is the method I used. Of course I installed another KD 21mm isolator over the Cree board
These are layers of kapton tape stickied on self-sticking labels carrier...being made to allow easy removal it work with the tape well... then I used a No11 scalpel blade to open the LED hole.
now comes the hard part....the P60 pill droped lower than the bigger module rim so I used two brass washers as a spacer. Soldered as seen they allow tight fit in the module and clearance for the driver wires....
Of course the whole mess is removable once I get the new proper drivers.
Fitting the Module in the Flashlight
The drop-in might fit but there are 2 things to be taken care of...
First A bare module would short the positive contact as seen above and it requires the contact being to be bent backwards some....
So here is the way the positive contact spring is bent and how it mates with the drop-in
Secondly, there is a chance of the positive contact leaf spring to touch the board negative rim...The arrow on the right picture points on a transparent isolator I made just in case....
I also soldered a small spring from another DX board...In the next mod I will be changing it to a regular P60 module spring.
And here is finished and installed....
Beamshots
All beamshots were take at auto-exposure...I know this is not proper for showing the beam intensities but the purpose was to show beam shape and characteristics and not compare output...
DX18073 Drop-in (XR-E Q5 EZ900 die)
Left Auto-Exposure, Right -2 stops from Auto-Exposure
Electrolumens AngleLux (Wayne's Anglehead mod with SSC P4 and IMS-27 reflector)
Dereelight 3SM-1 Drop-in on high
So there you have it.....
I will update this mod with the new driver as soon as I receive it....enjoy, Kostas
Beamshots
