Effulgence
I've got Minimags with the Auroralite kit using AW 14500s and the TL-3 lamp. I like the setup and the power from a MiniMag is fun to show off, but I have some problems:
The ceramic bi-pin piece is really annoying since it doesn't stay put, I was wondering if anyone has a solution to keeping it in place (like the stock plastic sandwich)? I was thinking of some kind of glue, something that would also transfer heat from the ceramic to the body better whilst holding it in place; it shouldn't heat and then drip onto the cells or that would be a big mess. I don't know what kind of glue to start with.
The TL-3 lamp doesn't want to stay put. After my walk in the park, the bulb sometimes pops right out of the bi-pin ceramic piece, how can I keep it secured in place?
AW 14500 cells tend to fit *quite* snugly in the body. It takes a few taps to get 'em out. I checked all my cells, it seems to have a small bulge at one of the sides, causing a size irregularity which seems to be the case. Duracell coppertops and other brands slide right out. Any suggestions?
Is it advisable to use Goldpro on the contacts? How/where should I begin?
What is a good clicky that's low profile that can work with this set up?
How long has everyone been using the H1499 lamps with this setup? Is it reliable? I've heard that this lamp is overdrawing for the specs of the 14500 cells. I'd want more lumens, but not at the expense of possibly having to treat your light as a grenade.
Can any fellow flashaholics help a guy out? Thanks.
