MM Lite specs?
StoneDog
Suwanee, GA
Wayne, does the MM Lite try to regulate voltage and if so to what voltage?
I suspect that lower Vf emitters are driven a little harder than higher Vf emitters of the same flux?
Jon
[ QUOTE ]
Jon
[/ QUOTE ]
Yes. 5 volts.
I couldn't find anything about the MM Lite's specific output. I'm very familiar with the differences between the boards, but I was curious at what level the MM Lite will drive a 1w or Lux3 and whether or not lower Vf emitters are driven harder.
doug, are you sure it's 5 volts? That sounds more like a MM or MM+?
Jon
