Mod Nuwai rebel
sfca
Westcoast
Hi,
Would like have a Nuwai rebel/Brite strike blue dot modded.
Here's a messerforum review (google translation) of the Walther version of the light, including pictures of the lamp.
I'd like it to be brighter.
And for the scratch-prone lens to be replaced.
Where the clip is the threads are drilled through sealed.
- Also, is there a way to tell the grade of aluminum used?
I like the body, 3 prongs, etc. I'd be down with a custom light that had those features too, depending on the cost.
Part II is:
Can you make this interface possible?
Press for momentary-high
Click on for constant-on high
Click-off and click-on immediately for constant-on low
- Any delay between click off and on will result in high output.
When in constant-on low or high, press for momentary-strobe
- When in low mode, activation and release of momentary-strobe will result in constant-high being applied
In other words, after application of momentary-strobe output will always be the highest
Thanks.
