Hi, I have been modifying the Romisen RC-T6 to the underwater light.
My light first received from DX was defective; normaly it powers 2->4->6 LEDs.My light powered 2->another 2->another 2Leds. So i exchanged it with new one. But the new one had the same defect.:mad: As the exchange at DX took a lot of time(1 month), I decided to repair it by myself. I found its defect occurred at lower voltage of battery. But with full charged battery it initially powered 6 LEDs but shortly did 6->4 and 4->2 LEDs. I thought the diodes connected to the switch were bad. so I exchanged them resulting no improvement. I knew the similar report that this light does not work well under 8 volts at another thread in the CPF. In this light the driver used is PT4115; this IC works above 8 volts!! To power 6 LEDs results the down of voltage of the battery and fails in lighting. I guess many defective RC-T6 might be sold...
Anyway I started the modification of Romisen RC-T6 to UW light with such the problem.
I ususally use the UW light with the UW camera. The flashlight is too long for me. So I cut it in two.
and removed the diodes and connected wires directly to the driver
and sealed the front and rear of the light part and front of the battery part
and made the waterproof switch. It works only 1 mode (all 6 Leds powered).
I tested it in the washstand. The initial voltage was 4.21Vx2(18650x2).
Reslut: Initially for 20 min it powered 6 LEDs(top fig.). for next 40 min 4 LEDs(inside fig.) and after then it powered only 2 LEDs(bottom fig.). I turned off the light two hours after beginning of test and immediately turned on it again but no light. The final voltage was 3.6Vx2.
The direct wire connection attained a little improvent. But I can enjoy the good brightness(6 LEDs) only about 20 min.
Next I will make the new switch which enables 2 mode(2 or 6LEDs). Usually I use it with 2LEDs and when I wish I will power 6 LEDs. But I think the basic solution is achieved only by the increasing the input voltage such as 18650x3 used. I must make the new battery box....
Anyone has a good idea?
To be cont.
To be cont.
