I've worked a lot with the basic LM334 current regulator circuit. I wanted to get this circuit working with a wide input voltage range, and also be able to handle high current and power dissipation while maintaing 0.1V or less of dropout. After playing around with a few different low saturation BJTs from Zetex, and trying to cascade the base current of the main transistor through another PNP transistor, I found it would be difficult to keep a very low dropout at low voltages, while keeping base current reasonable at higher voltages. I also found that my older design was causing up to 40mA of current to flow through the '334, which is bad, since the part is only rated for 10mA.
So I looked into using a MOSFET instead. I needed a P-channel MOSFET that could handle high current, could dissipate a lot of power, and had the lowest possible Rds with a Vgs of 2.5V or less
I found two MOSFETs that fit the bill nicely - one in SOT223 - the Fairchild FDT434P, and another in D2PAK (TO-263), the Fairchild FDB6021P.
Here's the circuit:
[edit] - this is the new circuit per the discussion below.
I built a low power and high power version.
Here are the two regulators:
The one on the left has the SOT223 part, and is set for ~550mA of current, while the right has the D2PAK part and is set for around 1100mA of current.
That's a quarter for size reference. The larger is 0.4" x 0.75" x 0.4". The smaller, 0.4" x 0.6" x 0.35". The smaller regulator can be made thinner by using a single board instead of two stacked board, and could end up being around 0.25" thick. Both are potted in epoxy for additional strength.
Both have an aluminium plate epoxied to the transistor for additional heatsinking. They both can dissipate between 1-2W alone. The smaller could probably dissipate 3W with additional heatsinking to the plate; the larger, could easily dissipate over 10W with a sufficient heat sink.
Both should work with up to 20V of input.
The zener and 4.7K resistor were added since both of these MOSFETs have a maximum Vgs of 8V, so the zener clamps that voltage, allowing a wider input voltage range.
I've done some measurements of both regulators:
Dropout of the high power regulator is 0.075-0.085V at 500mA and 0.085-0.095V at 1A.
Dropout of the low power regulator is 0.09-0.1V at 500mA and 0.1-0.11V at 1A.
I've been thinking about doing a run of these - though I'm not sure if there's enough interest. Price would likely be in the $5-$6 range. Or I could just let everyone build their own /ubbthreads/images/graemlins/tongue.gif
Here's the circuit:
![mfetregsch2.png](/proxy.php?image=http%3A%2F%2Fmyweb.cableone.net%2Fevan9162%2Fmfetregsch2.png&hash=9b96d98da33af143c18e94e133652d05)
![ldoregs.jpg](/proxy.php?image=http%3A%2F%2Fmyweb.cableone.net%2Fevan9162%2Fldoregs.jpg&hash=e8e014955b3a1433ebd70853d0c74a85)
