Want really really easy?
Grab a tennis ball and cut a hole in it just smaller than the MR-11.
Buy a socket from the light shop.
Poke a hole in the side of the tennis ball and feed the socket wires through from the inside.
Connect the bulb and run a bead of silicone glue around the hole, seat the bulb and weight down slightly. Wait till it sets.
At the local sports shop you can find plastic tennis ball holders. Cable tie to where your stem meets bars.
Wire in a battery, fuse and switch.
This worked fine for me up to 20w. Would not run anything hotter than that though.
Simple and weather proof, easily adjustable light angle.
Gets hot on the bench but not out riding.
You can put a head together in 20minutes so can run different bulbs easily. I had to build up the lip on the socket to hold things better but have found tighter sockets since.
Make sure mr11 has a glass front too...stops bugs getting in!
