Mr16 output help
mesa232323
bakersfield, ca
Anybody know the true output lumen rating, lux, and OTF lumens for a Philips mr16 50w module at 10 degrees beam?
I will be using 5 imr 26500 in a mag 4d with resistance mods to the cap, and high current rocker switch wired directly to the bulb.
Thank you for the info 5M. It was a 12 volt light but it was rated for 3000 hours. Not sure if that means it could be driven harder.
Hi,
recently I found a "strange" MR16 lamp and I wondered if a similar lamp has ever been tested yet ... well, here is the link
While not being especially efficient at 12V (only 800lm), wouldn't it take some insane overdrive at a claimed bulb life of 15000h (:eek:) ?
