jimsjimsjims
- Joined
- Aug 15, 2011
- Messages
- 4
I am doing a ground up LED set up in my kitchen and have questions about sizing bulbs to transformers. I've used Phillips 120V Powercore strip lights in the past with great results (once I got an elv dimmer) but am running into some problems now that I am moving to 12 volts. I was pretty set on the Endura series bulbs but was told by the rep that any transformer would need to be sized to the wattage that a bulb would be replacing and not the wattage of the bulb itself. In the case of one of my runs (12 bulbs) that would mean a pretty gigantic transformer. I looked into the Sylvania dimmables and their transformer compatibility docs show them to work with much lower power transformers (in one case the have 6x6 watts running fine on a standard WAC 100 watt electronic). I was hoping for a pretty high lumens/bulb (Phillips) but might be able to work with the lower power (Sylvania) if I had to. It just seems silly to buy a 750 watt transformer to run 120 watts of bulb.
My questions:
1. Is Phillips just being extra careful or is their bulb set up solely as a drop in replacement?
2. Are there any mr16 gu5.3 bulbs that are made specifically for lower power electronic transformers?
3. Any time frame for XLamp MT-G LED products coming to market?
Thanks in advance :)
My questions:
