Mattaus
Hi all,
I recently modified a 6D Maglite using a 6V MTG-2 and this driver. Now despite using 6 D-cells for a total of 9V, I'm getting some weird behavior in high mode that suggests voltage sag (I changes between H-M-L every second and just repeats. Note this is NOT what the specs list as a low voltage indicator). Given that an alkaline D-cell should handle 3 to 4A (?) I'm guessing the driver just may not be up to the task for whatever reason. That being said I have tested the setup with 2S Panasonic NCR18650 cells and high mode works fine even though fresh off the charger the pack voltage is lower (8.4V versus 9V).
So...what can I do? Are the six D-cells letting me down here? The build is for a friend and they really wanted to be able to use standard D batteries. Can someone suggest an alternate driver that provides less current but can supply the right voltage from the 9V source? My only stipulation is that it be relatively cheap if possible. My friend paid for the build but seen as it's technically my fault the driver is unsuitable, a replacement is coming out of my pocket...which he doesn't know about because there's no reason for him to worry ;)
Any suggestions are highly appreciated. I'm all ears!
Thanks,
- Matt
Thanks,
- Matt
