Aepoc
I just completed a sub-1D tri-XML Mag mod and had to provide a heat sink for the driver (kaidomain's 8X7135). Needless to say, the body that I'm using is very short and I ran into some troubles regarding space for components and heat sinking:
I had to modify Fivemega's 3x17670 battery pack by removing the nub on the negative terminal.
I had to remove the spring and provide a solder bead for electrical connection to the tail switch
Lastly and most importantly I had to permanently attach a wire to the positive terminal of Fivemega's pack.
This permanently attached wire makes recharging quite a hassle because it's attached to the positive portion of the pack which screws on to hold the whole pack together. Recharging requires holding the cap stationary, since its wired to the light, and applying torsion to the 3x17670's and the negative part of the battery pack...
There's very little clearance (~.02") between the positive terminal of Fivemega's pack and the copper slug used to provide heat sinking for the driver. The permanently attached (green) wire is getting pinched between the two and I fear it will need to be replaced soon. The whole setup would be much more user friendly if I could solder the green wire to the copper driver heat sink and provide a ~.02" solder bead for the connection to the positive terminal of the battery pack. This would effectively eliminate the need to have a wire permanently connected to the pack and make dis assembly for charging a whole lot easier.
Okay hopefully that wasn't too confusing... Here's my questions: Would the proposed setup subject my cells to an unsafe level of heat? Would adding a charge to the driver heat sink be just asking for a nasty, damaging short? Are there any issues which may arise that I haven't considered?
Any input in the form of warnings, suggestions, experiences, or alternate designs would be greatly appreciated.
Thanks in advance!
Thanks in advance!
