Multiple Surefire Turbo lamp holder
maxspeeds
Oahu, Hawaii
I've done a search, and from what I recall from my time here, I've never seen a holder that holds multiple surefire turbo lamps and/or 18500 & 18650 batteries.
I have LumensFactory plastic capsules for my lamps at the moment, but I would like to consolidate my lamps. A holder that could hold 4-6 lamps all in one would be ideal. The addition of holding 4-6 18500's and/or 18650's would be a plus. What does everyone use to hold multiple lamps and batteries? Carrying 4 SC2 holders is just not practical, and they also don't fit 18500 / 18650 cells.
I'm curious to see what others are currently using. At the moment, I'm debating of using a Pelican case and cutting out the foam to fit the lamps and batteries.
have you tried looking at the pelican micro cases?
I could fit 4 17500 and 6 cr123 and a knife in there. there only like 15$ and their waterproof.
[over-size image replaced by link. You may re-post it when you have resized it to comply with Rule 3. - DM51]
i'm sure you'd be able to carry some bulbs in there instead of a knife.
edit, my bad. size fixed
Another vote for the Pelican Micros. You can get a variety of sizes and colors, and they are great for cells and lamps. I keep an "M6" set, with 12 CR123s and a fresh MN20 just in case :thumbsup:. Lighthound stocks them, among others.
Here's a pic of a Pelican micro 1020 case...
I also use a 1060 case to hold my charger, cells, and bulbs. That one is a bit bigger though. +1 to lighthound, their service is top notch.
That looks great. Does Pelican sell foam for the micro cases (not the pick and pluck variety, but solid foam to cut?)
I use an old Eneloops box to keep all my M6 supplies. Fits a couple of 18650 carriers, the stock battery carrier, LA's, and cells.
I bet if you went to a craft store of some sort, they would have at least a couple of different types of foam. The only ones I remember from Pelican are the pick and pluck.
That's a great idea! Now I just have to decide which Pelican case will best suit my needs :D
