Hrvoje
Inspired by Orb Raw, I decided to make my own "poor man" version. My primary goal was to have regulated multimode driver and clicky switch. Because of that, my light is not as small as Raw or similar 14250 flashlight. I had few Cree P2 emitters lying around from my previous Romisen RC-G2 modifications, so decided to use it, but R2 is on the way for upgrade anyway.
I used 19 mode driver from DX (sku. 7882), and after adjustment, current is just right for 14250 cell. At the tail cap readings are 0.3 A on high, 0.07 A on medium and 0.01 A on low.
High is similar to Romisen RC-G2, but with more spill. Low is very usefull in total darkness, with the theoretical run time of 25-30 h.
I applied only thermal paste between emitter and the heatsink, and when the head assembly is screwed into the body, emitter is firmly pressed against the heatsink. When better emitter arrive, I can swap the leds without problem.
Reflector is also from DX (sku. 14598), as well as clicky switch (sku. 5604) and GIDT silicone tailcap (sku. 7321).
All in all, not the smallest and the best flashlight in 14250 group, but still usefull, and much cheaper then Raw or Draco :)
Hrvoje
Hrvoje
