kosPap
well I did it but it was an adventure...
The mod was a pilot one for the mod services I am gonna offer soon here In Greece.
I am partial to the 3C format though it makes driver choice difficult if you gonna run it on alkalines....
The Parts
Mac 3C
XP-G on 14mm board (KD)
H22 Heatsink
Bored through P60 pill as driver socket and heatsink
DX7882 driver sorry...
3xAMC7135 Driver
The Mod
Here is the hollowed out P60 pill and the XP-G mounted.....
I had to file the pill threads a bit and then it was lightly taped in place...
This is the switch module ready....hot melt glue takes the strain off the wires and I folded the original neg contact leaf back half wise...then fixed it bent with some solder...this way the mod is reversible to Incandescent. Please do not mind what the red promo lighter says! LOL
Days a go I made tests with the DX7882 driver, adjusted output at 1400mA with 3C Alkalines and then proceeded in powering it without the LED being wired....tsif! and a bit of smoke and no driver....
The second specimen was scarier! I could not adjust it below 2400mA! So much for all the planning....
So a 16-mode 3xAMC7135 Driver rescued things but once I had the mag working I found it is a bear to use these multimode drivers with the Mag Switch... If you want to get your mode on the first try, you better tap the switch and wait for the memory to set....
Uber UNtactical dudes!
Here is the driver in place...Keen eyed members will notice that the driver board is too thick for the socket...being raised makes soldering difficult and messy....
I do have a method of filing off the driver a bit and then jamming some braided wire at the void, but I did not had time to do it. Time was past and I was already late for a meeting....
Measurements
High at 722 lux in my lightbox (a DX one that meters about 30% lower than the Metermans). From experience that is close to the 300 lumens range if not more
Medium was 264 Lux and Low was 55 Lux.
And hotspot was 19670 hot ones! That makes it around 26000 Lux adjusted!
that’s all folks, thanks for viewing...kostas
The Parts
Mac 3C
H22 Heatsink
3xAMC7135 Driver
The Mod
Measurements
