jrmy0641
- Joined
- Aug 19, 2008
- Messages
- 63
It is my first surefire (and $100+ light). I was a little underwhelmed at first. The beam isn't very pretty; i later discovered that there is a series of scratches on the reflector. These cause a line of light brighter than the rest of the spill to appear in the beam. I don't think it's worth sending it back. It was still daylight so i white wall compared it to both my l2d and d10. The d10s max is about the same as high on the l2d (~109 lumens claimed by fenix). The l2ds hot spot and spill are wider than the e2dls, maybe making it a more useful light. The l2ds spill is also about twice as bright (on turbo). However, the e2dls hot spot is very noticeably brighter. Maybe 2 times as bright as the l2ds (on turbo; 180 lumens claimed by fenix, 120 by surefire). Still, due to the lackluster quality of the beam and apparent lack of quality control (the reflector scratches), i was ready to make a thread here asking why i spent 3x the cost of an l2d on the surefire: The build quality is good, but my l2d feels every bit as hefty.
Until i took it outside in the dark. The e2dl dwarfs the l2d in throw and brightness (at the same distance, the e2s beam is 2-3 times as bright). The ugly beam even disappears after so many dozens of feet . The bezel does heat up rather quickly and it's weird loading the batts from the bezel end I also wish that it would have come with a lanyard -- who doesn't give you a lanyard now and days? A few even come with extra o-rings and switches (which reminds me; I'd like for the switch to be a little more firm) Other than that, it turns out that I'm a lot happier with the light than i was at first.
I should have a comparison up of the l2d q5, d10, e2dl and dbs v2 (if it arrives on time and just for fun ) by next Tuesday. Looking forward to that.
