Mark_Paulus
As it was starting to get dark on my commute, I finally got off my duff and put my fatman powered 3x3 S*** bike light together.
I used a Craftsman 2D task light (an older style, with an all aluminum case and bezel/head, instead of the newer partly plastic head). I managed to use a modamag Perfect Tri Sink (the thick one) with 3 S*** LEDs. Put a Fatman @ 900 ma, and am running it off of 2x 18650 2400 Mah Li-Ions. Works great as a bike light, as I get a pretty good punch/hotspot so I don't worry about outrunning it, but I also get a nice sidespill, so I'm seeing up close enough to not feel "blind". It's a nice trade-off.
I have a question about this setup, tho. When I use the cells freshly charged, the fatman is pulling about 1.5 amps @ 8.4V. When the cells run down a bit to 7.6V, the fatman is pulling about 1.9A, or a bit more. Does this seem reasonable? Also seems to give around 1 hour of runtime or so, which is enough for 1 days commute (about 45 minutes). I do carry a spare set of cells, and try to charge them every day.
It was a bit in the making, but I'm happy with the results, and find it a very useful setup.
