ahorton
- Joined
- Jul 22, 2008
- Messages
- 715
I actually made this months ago but thought I might post it up since I learnt everything from this forum. I've made about 5 different headlamps but this is my favourite so I'll show it.
It's going to become obsolete soon anyway since I have requests from more than 20 friends to make one for them which means I'll be getting them CNC made. For a homemade headlamp though, I can't imagine it being much better than this for my use. It could have been cheaper though since I used to buy from Cutter and am now a DX convert. Hence the Buckpuck in this version while my future lights will be AMC7135 driven.
The strap, battery pack and front mount are from a 10 year old Petzl Zoom.
The aluminium head is a bit of scrap c-section and the heatsink from this.
Mass without batteries is 196g.
The waterproofed toggle switch flicks between the 2 modes.
High: R2 driven at 1A by a buckpuck and focused by a 30mm Aspheric. The lens is held slightly closer than the focal length because I like to have the widest beam possible at 100m throw.
Low: 4*5mm LEDs in 2s2p getting on average 30mA each (just resistored).
Battery pack is 7.4V and I have two types as shown. The one on the right is made of 2 DX 18650 2500mAh protected cells.
This closeup photo isn't great but it shows my LED mounting. I actually soldered it to brass rather than copper. Copper conducts heat better, but I liked brass being stiff enough that you can use stainless steel bolts to put a huge amount of pressure on the contact surface. You notice it when much more of the interface material (Arctic Silver in this case) gets squeezed out.
The little lip at the bottom solves a problem from an earlier design in which a tiny bit of light from the 5mm LEDs reflected off the user's glasses and drove them insane. I didn't think about this at first since I don't wear glasses but my dad got back from a 24 hour bush race and made the suggestion.
