65535
I would say beef up your batery carrier by soldering wires from the tips of the springs to the tip of the other spring it connects to. on every spring, then chekc current again.
Sounds like you've done everything correctly your reading is low because of the extra resistance in the battery holders. As mentioned before you need to do tail spring mod, switch mod and buy a fivemega battery holder. Or you could also have a custom battery pack made up. http://www.cheapbatterypacks.com/main.asp?sid=650346&pgid=loosecellsJRS7 said:I pulled the tailcap and touched the Red lead to the bottom battery holder, touched the Black lead to the Mag case, and boom the light comes on. Have the meter set on 10A...(with a - above the ...), the Red lead is plugged into the hole that says 10A DC. The Black lead is in the one that says Com. Is this correct? If so, it's messed up, because the reading on the screen is 1.26
not2bright said:Given that you have taken the Mag tailcap spring, switch, and PR socket out of the equation by hooking the cells in holders directly to the lamp via the meter, I would suspect that your cells aren't holding up to the load or the cell holders are highly resistive.
It would be my first guess that the cells aren't supplying enough current. If you want a quick fix that you can get locally go for the Sanyo eneloops (Circuit City maybe?) or Rayovac 2100 Hybrids (Walmart $8.97/4 pack).
I am using the Rayovac Hybrids in my ROP HI without a problem. I am reading 3.6A from the 6 Hybrids driving the Pelican 3854 HI bulb (black lead to the bottom of the cell carrier and red to the outer edge of the flashlight).
I think you are using your meter correctly, but it is showing you that you aren't getting enough current to the bulb.
tebore said:Shouldn't a ROP HI read well over 4Amps? Sounds like the Hybrids are holding up to high drain either.
Not necessarily. Resistance increases with current, so if you had proper batteries that were supplying ~3.5A on your table setup, you may see a good drop when in the light and checking at the tailcap with your battery holders.I realize they are cheap lousy battery holders, but the reading is almost the same WITH OR WITHOUT the battery holders....so if I'm doing the reading right then what it's telling me is that the battery holders are not so bad, but my batterys are junk......problem with that theory is that another set of batteries reads the same.
not2bright said:tebore, I assume that you meant they AREN'T holding up to high drain.
The 3854 HI is listed at 4.15 on the lithium version as far as I know. And for the 3.6A number I posted, I literally grabbed my ROP that has been sitting for 4+ weeks (with some use over this time) and took a measurement. I guess I could charge up the cells and take a reading with a fresher charge if you are interested.
The point of my post is that the Hybrids will do better than 1.29A that JRS7 is seeing from his Duracell 2650/Energizer 2300 setup. And the cells are most likely available locally for a reasonable price. Add to that the benefits of the low self discharge with the eneloop and hybrid and you have a "always ready to go" light.
JRS7 said:One more quick test before I hop on the treadmill:
I just quickly checked my G&P Scorpion the same way, and it's reading 1.23, so I'm fairly certain I'm not using the meter right (or it's piece of garbage!!)...................I know that the Scorpion is 'healthy', don't know how many amps it draws, but I'm pretty dang sure it's more than 1.23?
JRS7 said:If you swap the red and black lead, it goes from 1.23 to a -1.23
The Meter belongs to my brother, maybe it won't read amp draw.....I'm going to take some pics...
