On Friday, I received my new Dereelight CL1H v3 3SD with both SMO and OP reflector. I like the light so much, it is difficult to take it out of my hand :twothumbs.
Here is a picture taken on my first trip with the light, only lit by the Dereelight:
The PWM regulation of the Dereelight has been debated in other treads in the forum. My light makes no sound that I am able to hear. I do normally not notice the flickering of the light, so it does not bother me at all. It has a very nice effect when using the flashlight in rain, where the drops appears as blinking pearls when the light is dimmed down.
According to my measurements, my light uses 1.33 A on max on a fresh 18650 battery. On a battery that had been used to a rest voltage of 3.9 V, it used about 1,5 A. My Ultrafire battery lasts for about 1 hour and 45 min on max without any noticeable drop in light output, and then drops very suddenly. On medium setting, it uses about 0.4 A and on low about 0.09 A. Even on low the spot is visible over 50 m.
Here is the lux measurement taken in a plane 1 m from the lens of the light. I have described my method for this and for the lumens calculation in an earlier post.
As you can see, with the SMO reflector I get about 232 lumens according to my calculations. With my OP reflector, I get a somewhat larger spot of a little less intensity, and about 209 lumens.
Hope you find this of interest, and if any questions, please just ask.:wave:
