brightnorm
- Joined
- Oct 13, 2001
- Messages
- 9,027
In brief:
Appearance
Sleek and elegant flat black HAIII. Looks as "professional" as any product from the finest source. There are two O rings.
Fit and Function
Tested bodies: E2, E2e
Tested bezels: Standard aluminum (including M2 which has standard inner diameter), SRTH Turbohead (combined with standard SF turbohead adapter), KL3.
Nitrolon: G2 and G2Z
The E2C threaded smoothly and functioned normally with all tested body/bezel combinations. A few very minor clicks and bumps were occasionally felt during threading, but in no way impeded fit or function, and will most likely disappear with lubing and use.
HAIII
Easily passed the scissors/screwdriver "scrape test"
Ergonomics
Since the E2C weighs only .7oz it was not responsible for any perception of "nose-heaviness", but mating an E2X body with standard bezels sometimes produced that effect, though generally to a modest degree.
The adapter's "first ring" (closest to the body) created the effect of making the E2 body seem slightly shorter than normal.
Comments and conclusions: I realize that Don had to size the two "rings" to accommodate the E2e's permanent clip as well as the standard bezels. Personally, I would like to see an E2C with the "body ring" diameter reduced to E body dimensions to avoid that first ring "body-shortening" effect. This would work beautifully with a clipless E2 body, but might raise manufacturing costs to unacceptable levels.
The E2C is a really beautiful piece of work that should make Don proud and Flashaholics happy.
Brightnorm
Appearance
Fit and Function
HAIII
Ergonomics
Brightnorm
