First I just want to say hi ahead of time as I have been a long time lurker but am new to posting here. After reading several posts I decided to purchase my first researched high power LED Light, a Fenix TA21. I bought the Fenix TA21 from mycornerstore.com for only 67 dollars.
The light is good with the exception of it running for only around 2 min continuosly before it turns off! After turning off it wont turn on again for a couple hours. When it is off, and you try to turn it on, the led flickers so extremely low that it is almost impossible to see. It stops flickering when you turn it off again. A couple hours later it works great again for the 2 mins before I have to repeat the cycle. The light does not feel hot either when it turns off. In addition, taking out and putting the battery back in does nothing to fix the light as well. I'm new to buying flashlights as I have been using just my duty issued stinger. I also used to have a gladius that worked great but used up way too many costly batteries. Im using a new AW 18650 Protected 2600 mAh Rechargeable Lithium Battery (that I bought from lighthound.com) to run my Fenix TA21. I havent dropped the light or done anything to it other than carry it with me on duty.
Does anyone happen to know what the lights problem is? Could it be the battery or is my light defective? What should I do? Does this happen to other high power led lights? I really hope that you experts can help me out! Thank you for your time
