Yes, those shots were on high for both lights. The EX10 is clearly, but not tremendously, brighter than the NovaTac based on side by side comparison of both spot and spill intensity (I didn't do any semi-formal bounce tests, but I didn't feel there was any need to confirm what I was seeing, it looked pretty cut and dry). Don't take this as definitely confirming any brightness claims though; based on a few informal comparisons, I now believe my 120P is just slightly short of 120lm, probably closer to 100-110lm.Great comparison pics with the Novatac.
Were both lights on HIGH by the way?
If not, can you tell me which is brighter ON HIGH of the two?
Changing the background from grey to white will GREATLY improve the readability. As a former instructor, printing out charts with grey background (the default) instead of white earned a 5 point deduction in my grade book after the first week.
The gray background is the default for a reason. It is the best background to use most of the time. I don't know were you get that a white background will *GREATLY* improve readability. What do you base this on?
This interface brings uncertainty into my life I am not sure I'm ready for. One through nine, no maybes, no supposes, no fractions. You can't travel in space, you can't go out into space, you know, without, like, you know, uh, with fractions - what are you going to land on - one-quarter, three-eighths? What are you going to do when you go from here to Venus or something? That's dialectic physics.
These are just quick shots I took last night for my own reference and I had no intention of sharing them, but since you asked...
I have a few NovaTac/EX10 comparison shots here.
The EX10 is using an RCR, 120P is on a primary. I don't think the brightness difference was quite as big as it appears there, but it was noticeable.
That's a valid consideration.I look at this light a bit different. It is a 3 stage light, with only a single medium stage being adjustable. The other 2 stages are fixed, Max Hi; and Min LOW. The big disappointment for me is that you lose the memory of the adjustable setting when you access the fixed settings. Whether you want it or not, the last fixed setting accessed replaces the adjustable setting in the memory. For the user who wants his light to quickly come on in Max or minimum every time, this would seem to be a quick and convenient way of setting one of these fixed stages into the memory. For the user who wants to access his user defined setting most of the time, this is only convenient until he accesses one of other 2 stages. He then has to reset his adjustable stage.
There are fingerprints on the led lens, you can clearly see them on low.
Does anybody know how to disassemble the reflector head for cleaning purposes?
Imothep, I'm sorry your light. It shouldn't affect the output noticably.Well, its definitely on the outer side of the epoxy dome. That is clearly visible when I slighly move the flashlight while watching the led.
I tried to make two more pics but since I don't have a macro lens they are not as good as they could be.
AW + Charger would be ideal for the D10 but the start up cost you have to consider. The next best thing is to pair with Eneloops.
Please contact our customer service department and our technicians will give
it a good cleaning. I have spoken to NiteCore and this won't happen again.
They are appreciative of this feedback - they do not see this as a complaint
but rather a great opportunity for improvement!
Well, thanks for the help, but I'll wait for the second D10 I ordered. One of them will be a present for my father and since he doesn't care about fingerprints, he will get this one. :devil:
