TallNHairyDave
Well, it's arrived. So here goes with a review.
The box when it arrived from Heinnies was smaller than I was expecting and contained my order of two MaxP Volta battery cases, a set of MaxP Sliplocks and the TK40:
Sliding the cardboard outer off revealed an inner, translucent hardcase:
With fold up handles (nice touch)
Opening that revealed the torch and it's accessories all in handly compartments (downside - the metal clip of the shoulder strap has very slightly marked the tailcap of my torch - just visible as a white spec in the photo. In reality, the scratch is about 1mm long.)
The downside of the case (apart from that mentioned above) is that the moulded hinges seem quite thin to me, and I'm not sure how long they'll last for if you use the case as a storage/carry option for the torch regularly. Still, the fact that the torch comes with a custom hard case is a nice touch.
Unpacking the case reveals:
Clockwise from the bottom:
Now, a lot of the quick reviews I've seen so far of this torch seem to have failed to figure out what the mystery lanyard is for, and it had me stumped for a while as it's too damn short to work as a wrist strap. But I finally figured it out!
Moving on, I decided to compare the size of the torch to my Solarforce L2 (which is about the same size as a Surefire 6P). You can see in this pic how the shoulder strap attaches. Oops! I've given away the surprise I was saving for later in the review!).
What strikes me is that the torch isn't HUGE or too heavy, even with 8 AAs in the battery holder. You can carry it in your hand without getting tired.
Speaking of the battery holder... To get it out of the torch, you can unscrew the head or the tailcap. The gotcha being that the bit of the tailcap you expect to unscrew doesn't - it's the very tailmost ring that unscrews.
Here's a closeup of the battery holder loaded with eneloops. It looks exceedingly well made and does the job nicely. Batteries go in the holder with the negative side towards the spring.
Thinking of batteries, the manual tells you to unscrew the head 2.5 turns when not using the light for a while to avoid slow discharge of the batteries. Not sure why this should be so?
Meanwhile, back to the mystery lanyard thing...
You attach the split ring through one of the two holes in the tailcap and clip one end of the shoulder strap onto that....
Then you loop the mystery lanyard around the head of the torch and clip the other end of the shoulder strap onto that....
et voila!
You can then carry the torch slung over your shoulder. Nice
Operating the torch is pretty simple and is ALL through the tailcap clicky switch.
If you have it flashing and turn the light off then on again it comes back on in the PRIMARY (non-flashing) mode.
Turbo is DAMN BRIGHT, but they warn you not to use it for more than 15 minutes at a time.
Indoor beamshots to follow when it gets dark! Will get some outdoor ones at the weekend.
- TK40 torch
- Shoulder strap
- Instruction manual
- Warranty form
- Small advertising brochure
- Ziplock bag containing spare tailcap, 2 spare O-rings and a split ring
- Mystery woven lanyard thing
et voila!
- Pressing the tailcap switch turns the light on and off, and it remembers the last PRIMARY mode (low, medium, high, turbo) you used.
- With the torch on, hold down the tailcap button for 1 second to go to the next mode. (You have to release and press again for 1 second to go through the modes. Keeping the buton held down does NOT cycle through modes)
- Double-click the tailcap switch to activate the flashing mode that goes with the power mode you are currently on.
- Low power = Slow flash (About 2 seconds between flashes. Would make a good locator beacon?)
- Medium power = SOS (This is a SLOW SOS flash in morse code)
- High power = Fast flash (probably around 1/2 second between flashes?)
- Turbo power = Strobe (Holy !&$# That's disorientating!)
