I received my RC-T5 about 2 months ago. It came not bubble wrapped and the glass lens was smashed in. I had to have a local shop cut a normal plastic lens witch the Attendant promptly turned in to a partial diffuser lens by Cleaning it off with a paper towel. I would like to get a tempered Pyrex lens the diameter is 46.5mm and DX dose not sell these yet. The over all ergonomics of this light are excellent but the output is a little weak compared to its potential. I want to use a shark board to boost the output. There is a thread on this already here:
http://www.candlepowerforums.com/vb/showthread.php?t=194390
While I was taking measurements from the head for a bicycle mount the slug came loose from all the screwing/unscrewing. The light would only stay in one mode and when i tightened the slug up the function returned to normal. It would be nice to put a set screw in the face to prevent loosening due to head removal. While I was fixing the loose slug I noticed that one of the lenses fell off a CREE. Can this be re-glued? If not can i just replace the emitter or board? I have the Q4 emitters with the silver background so this is the WC model? The boards are 16mm versions. Should I replace the whole board with :
http://www.dealextreme.com/details.dx/sku.3417
If it is the yellow type that will throw off the whole color balance. Is there any way to get the proper SKU for the emitter I have? Should I just go ahead and upgrade the 4 Q4's to Q5's to get a proper matching set?
