Myo XP-V2 mod to XR-E Q5
Status
Not open for further replies.
People have done that, as I recall. The beam pattern was poor. The SSC is a better match for the optics. If you search CPF you may find the earlier attempt.
I suppose the MC-E is out of the question with the heat issue correct? I dont so mcu care about the beam as raw flood light.
The drive current will not necessarily increase by changing the LED (unless the Vf drops...). Also the heatsinking is a problem in these plastic lights, so the current will probably not change much.
However, the MC-E is more efficient at the same current due to the larger number of dies at lower current. And the larger source size may be good for flood.
I think you'd have to try it to see what happens. It is hard to predict. It would need to be a Parallel MC-E setup to have a similar Vf.
Is there a sticky where I can read about s/p vf va and all the other crap?
Vf is forward voltage of the LED diode. There is lots of good info in these forums, but it takes a bit of digging to find it. The wiki is a good place to start, though it is not complete yet. The stickies in the forum on flashlight electronics is good.
[Emphasis mine]
Gentlemen … I believe a hobby, an area if interest, indeed for some a way of life has just been … dissed.
BTW, mr. child, hot-linking to images on other's websites is verboten. Moderator will probably be along any time now to give you a sound fanny warming.
:popcorn::popcorn::popcorn:
:twak::whoopin:
:clap::clap::clap:
[Emphasis mine]
:twak::whoopin:
:clap::clap::clap:
Im seeing a pattern of overly-sensitive people here.
It depends on your perspective, I suppose. I'm seeing a rude newbie who apparently can't be bothered to read the rules and hasn't yet learned how to behave himself.
You have already been warned once about this, but you seem to have paid no attention. Take a few days off, and when/if you come back, you'll be expected to comply with forum policies.
Status
