Need a replacement for a 1xAAA light
magnumrtawd
I had a small 1 aaa led (cree) type light that I carried in my pocket that I recently lost. It was a Nebo, I think. I can no longer find one.
What would you reccomend to replace it?? I am considering a
BJ08A 3W 180 Lumens Q5 Aluminum Mini LED Flashlight as a replacement.
Link removed as per the banner at the top of the page - Norm
For all questions please select all that apply.
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
__X__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
Xthan $25.
____Less than $50.
____Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
___X_I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
___X_Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
X(known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
___X_I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
__
_X_I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
___X_I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
___X_5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
___X_Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
___X_Slightly Important (Walks around the neighborhood).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
___X_I don't care.
____I don’t know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
___X_I don’t care.
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
___X_I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environment.
Originally Posted by was.lost.but.now.found
2) Budget
___X_I’m flexible, tell me what you gotJ.
___X_LED (usually better for efficiency and small size)
____Incandescent (usually better for color rendition)
____HID (usually better for extremely long distances, but often requiring a larger-sized light)
____I don't know
6) Manufacturer:
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this option can provide more options to the consumer to meet specific needs. Often this type of light is more easily upgradeable as technology improves.
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply. Note that a high degree of throw (i.e. for long distances) often requires a considerably larger/wider reflector.
____I want a twisty switch (twist the head or the tailcap to tighten, and the light will stay on until the head/tailcap is loosened). This type of switch is potentially the most reliable.
____A simple on-off is fine for me. I only need a single output mode for this light and have/will have other lights for other uses.
____Anodized Aluminum – either type II (usually black but sometimes available in a wide variety of other colors) or III (hard anodized, usually tan-to-olive in color but often available in black as well) (Aluminum is the most commonmaterial for today’s flashlights).
My EDC is an Olight i3 EOS. Runs on an Eneloop AAA, has three modes, the brightest being about 70 lm. Shining Beam website has it for $21.95, which includes a AAA alkaline battery.
+1 on the Olight i3 EOS. I have the older version, but it has been on my keychain for 2 years. Great light. I have owned a few other brands, but like this one the most. It has low, medium, & high. It always comes on in low which is a must for me. I do not like edc lights that come on in anything other than low first.....I don't like getting blinded when all I needed was low.
