Ofelas
- Joined
- Mar 7, 2007
- Messages
- 204
Hi all, newbie to the current crop of LED lights. I was perfectly happy with the relative warmness & durability of my incandescent 6Z until I lost it. I also understand the 65 lumens of the old 6Z is almost matched by today's very useable Cree 30 lumens EL1, as SureFire underrates their output & has improved their beam/reflector technology.
I want to go with a compact EDC single CR123 cell unit that can take some abuse and rough handling. It will do double duty as a small light source for backcountry usage (occasional throw, with some 3 second bursts for quick trail identification) and will certainly get dropped on rock, wet, probably dunked & be used in occasional sub freezing weather outdoors.
Nothing extreme, so I don't need over-engineering/nuclear fallout resistance.
I browsed here & came up with -
1. SureFire Cree EL1 - simple, no fiddling around, instantly deployed with the instinctive click on/click off button, no brainer 5 hour runtime at 30 lumens + 5 hours at diminished capacity. How diminished, may I ask? A rough lumen rating?
2. SureFire Cree L1 - almost as compact as above, but fiddly twisting and/or two step click level settings. However, interesting two level brightness; how bright/useful is that low 10 lumen setting anyway? I will not be doing much low light work with these flashlights, I use a red LED Photon-2 for that.
When I need to deploy a flashlight fast under duress, I want to do so one handed, and with simple motor movements. Hence my initial consideration of the EL1.
I reckon what it boils down to with the above is 30 lumens for 5 hours (EL1) or 65 lumens for 90 mins. (L1).
Or, in my boiled down reasoning, 150 lumen-hours on high for the EL1, or 98 lumen-hours on high/160 lumen-hours on low for the L1 before I change batteries.
I've heard in the real world there's not much visual difference in the 'brightness' between the EL1 & L1. (not double the luminosity/light output anyhow). True?
3. Lastly, for what I want, how does a Fenix P2D Rebel compare as to the above two SureFires? The high lumen rating over a long runtime seems incredible from such a small light. Is it rated differently? Same fiddly twisting mechanism?
Real world comparisions from folks who've used any or all of the above in the field?
How good are the CR123 batteries that Fenix Store offers as compared to the SureFire or Energizer brands?
Still confused on whether R123 batteries will work on all the above three flashlights.
Thanks, will base my impending purchase this coming week on y'alls input.
