Need help id'ing AAA light
Status
Not open for further replies.
sleidig1
Need help id\'ing AAA light
I recieved in a trade a used Arc AAA flashlight.
The plastic package has a sticker that states it is an "AAA-LE", but the insert under it has a sticker that states "AWS-NAT-P Premium white LED natural finish"
The body of the flashlight itself has the following words typed around it "L.E.D. *AAA*-ARC FLASHLIGHT. LLC" and the word "premium" around the base.
The head or led piece has no labeling at all, just a black rubbery pad to prevent battery rattle.
Is there a way to check to see if this is actually a limited or premium head & not just a standard on a premium body?
Re: Need help id\'ing aaa light
someone please correct me if I am wrong. The AAA LE (limited edition) and the AAA-P are one in the same (not sure what the AWS-NAT-P signifies. I'm pretty sure that identifies it a a AAA Premium) one the later incarnation of the other. I do not know if when the change did take place Arc was still packaging the newly titled AAA in the old packaging. Then again it was a trade and anything is possible.
FT, you are correct. It sounds like an AWP-NAT (Premium) with the warmer LED tint.
The name for the Premium Arc-AAA was changed from "Limited Edition" to "Premium Edition". This was shortened to just "Arc-P".
Peter
there you go Sleidig, right from the horses mouth, sort to speak ( no offense Giansee /ubbthreads/images/graemlins/smile.gif ). I believe you can rest now assured that you have what you thought\hoped you had.
Thank you all for your help.
I should have asked "is there a way to id the head or led as a LE or premium without having to rely on the base unit? "
Just the color of the LED. The LED used is the only difference between a standard and Premium head.
Peter
i bought what was supposed to be a premium AAA from a CPF'er but the tint is real purple.
Status
