Hello.
I called Arc but was told "that department" went home early so I need to call back Monday.
So since I have time I thought I would post my issue here and hope for a solution.
I got my Arc6 about 10 min ago. Tried to use it nothing happened. Tried a new battery and got some light. Checked the battery they sent with the light and it read 1.97 volts. The battery was not in the light when received.
So I used my new battery. Tested that it read 2.97 volts. Switched to a powerizer battery that read 4.02.
While using both these batteries the light comes on bright and then dims. When programming as you go through the levels they all come on bright then dim. I can't get this light to work.
Any ideas?
By the way it did not come lubed either.
Rob
On a side note- I am really negative right now. I am so upset I have to call back Monday. I think the 30 day return policy may work in my favor here.
Any ideas?
Rob
