bluecrow76
I'm building a quad emitter M@G with the maxflex driver. I have the entire head built already with 26 AWG silver teflon wire.
I've done some searching and have found that the max current I should put through this wire is 2.5A. I will be driving this light on either 2x18650 (7.4V nominal) and up to 9AA (10.8V nominal). Should my 26AWG wire to from the switch to the driver be able to handle the current??? I know the higher my input voltage the lower my current draw will be. I'm going to keep it set to 700mA normally, but I don't want to have to worry if I want to bump it up to 1.2A output.
Thanks!
Thanks!
