Need led/driver suggestions
tinkerer
Hi
I like to make a molle style angle head light and need some suggestions on which driver and led combination to use. I was in my local home Depot and noticed these pvc electrical boxes. They're gasketed and the perfect size to house a C battery. I intend to install a rubber booted toggle switch on the bottom using the existing collar as a shroud.
Anyway these are the parameters I like to have:
-powered by 1 c battery
-long run time(8 hr. +)
-around 20 lumen output. I don't want to sacrifice run time for output as this is intended as a emergency light.
Thanks for any help!
