I wonder what candela this would do with dedomed emitters (and any current boosts)? And how it would compare with your modded Supbeam X60?Hi Vinh,
I wonder if you would work on fenix rc 40?
Dien
Max
Hi Vinh, I read through previous postings and learned that you no longer do nitecore EC25 mod other than emitter swap?
How much would it cost for you to swap to dedomed XML2 1A with proper focusing?
Thanks!
I'm lookin to get a couple of lights modded and I'm curious to see what all you can do. For sure I would like an emitter swap on a Fenix LD12 from the original XP-G to an XP-G2 or an XM-L2 PDT to 5000k. I'm looking to keep about the same run times and intensity and I'm hoping that an XM-L2 de domed might be able to keep up with the XP-G between the narrower spill angle and increased output. The other I'm looking for is either my Quark 2aa Pro LED swapped to an XM-L2 PDT to 5000k or something similar in the old Fenix LD20 or the newer LD22. Also, as a side note, if you think you could tackle a couple of harder projects, I'm looking to tinker with the draw on the lights listed above and I would like to drop in an MT-G2 into a Fenix TK41 with around 2000 OTF Lumens if at all possible. Oh, and naturally I would need everything engraved
Cheers,
SZ
Hi Vinh i have posted my Thrunite Tn 32 to you to work your magic on max throw please also is it ok to run torch on 3 new Nitecore 18650's 2600mAh thanks Pete.
Vihn,
have you done any work to a eagtac mx25lc3
mine is a 6x nichia and I really want 4000k xpg2, can you up the current also
trevor
Hi Vinh,
I had a few questions:
1) Do you do mods on the Sunwayman V20C magnetic control ring light? From the factory it puts out about 550 lumens; another CPF member thought it was running the XML-L2 at about 1.5Amps for reliability and possibly to keep the losses low with that magnetic control ring.
2) Can you increase the amps to put out more lumens without decreasing reliability too much?
Vinh could you help me turn my little suzuki jimny offroader into a lumen monster. Id like to mount some kick *** lights that will frighten dark into submission! I like throw so food for thought. What do you think?
