need recomendation for an LED flashlight. and batt
alfred
requirements would be.
at least 3 watt luxeom
can run with rechargeable li-ion batt
maximum6 inches in lentgh
should be available in black
li-ion battery should be protected from over discharge
any suggestions would be appreciated, if you give suggestions pls post where can i actually buy the item a link or any contact would help
thanks
Start with a Surefire E2D or a Aleph body.
Get Pila batteries from J.S. Burly's
Get a Aleph head from McGizmo or The Sandwich Shoppe
You will need to read up on Aleph heads so that you're sure to get what you want.
You might want to get a two stage tail cap too. You'll find the information while you're reading about Aleph heads.
With a Aleph head you can change from a Luxeon III to a Luxeon V if you have the parts. You can get the parts (light engines) when you have your lights built.
I prefer 5 watt Luxeons (Luxeon V).
McGizmo's Aleph fits all the requirements. It is one heck of a light. Comes in three body sizes as well as three reflector sizes. It can be had with a Luxeon III or a 5 watt LED. I prefer the Luxeon III, it has a good tight beam with decent sidespill. Aleph Pricing and Ordering Instructions
