Bobo The Bear
- Joined
- Dec 29, 2008
- Messages
- 34
Long time lurker, first time poster. I've been looking for some type of "charging FAQ" but did not see one.
I'm just getting into the rechargeable battery scene after seeing my 4 year old burn through alkalines with all his toys.
I have a La Crosse BC-900 which I'm pretty happy with. I'll probably get a Maha C9000 someday, but not anytime soon. I use Duracell 2650 mah non-LSD rechargeables and Eneloop 2000 mah LSDs, depending on the application (nothing fancy, toys, remotes, etc.).
My question is pretty simple, what's the correct charging (and discharging) rate for these?
Everything I've read prior to discovering these forums is that lower is better. Heat is bad. So I've been charging everything at 200 ma (and discharging at 100 ma). Printed on the sides of my Duracell 2650s it even says "Standard charge 270mA for 16h". It takes forever but I'm in no rush.
After spending a couple days doing searches on "Eneloop" I'm reading different now. I see people recommending charging at 0.5C to 1.0C which if I understand correctly means 1000 to 2000 mah for the Eneloops and 1325 to 2650 mah for my Duracells. Is this correct?
While I'd love for this to be true (I could recharge more batteries in less time) it kinda goes against everything I've heard up to now.
Thanks for any insight.
