Robocop
Mammoth Killer
I recently purchased a few 18650 AW branded cells and am using them in my M90 with various lamps. I had used them for one night only when the light shut off after what seemed like 30 minutes or so of total usage.
I charged them up for the first time and they showed fully charged after about 30 minutes. This seemed weird to me however showing fully charged on my volt meter I tried to use them again tonight. The light worked fine for about 30 seconds then shut off. I removed the cells and both showed 4.15 volts so I tried again when the light shut down after 10 seconds again. If I let it rest and keep trying it will work every other try however something seems to be triggering the cut off circuit of the cell or cells.
When I remove the cells and test with a meter they show both at 4.15 volts so I am having trouble finding which cell is malfunctioning or maybe it is both. I thought it may be the lamp or tail cap however the light is brand new and works fine with my other 18650 cells.
Any idea of what is going on? I thought if the protection circuit tripped the cell would read 0.00 until reset on the charger. Is it possible one or both of these cells is more sensitive to the current draw and is shutting down.
This has me puzzled and I appreciate any help. Right now I am using both cells in single cell lights trying to drain them so I can try re-charging from a lower voltage.
