kj2
Also check eu dot nkon dot nl. Large choice on li-ion batteries.
Acebeam told me, the K70 draws about 7A from the batteries so think the Sanyo's are the way to go.
It's definitely not pulling 7A though each cell! (Could be 2s2p).
You can do a rough back of the envelope calculation to estimate this:
The XHP35 HI is rated at ~12V @ 1.05A maximum spec. To achieve the lumen output of the K70, the LED would need to be driven at about 2A and Vf would rise to about 15V. So LED is driven at around 30W. Factor in say 80% driver efficiency and total power draw is ~38W. Current through each cell assuming it uses 4 x 18650 would be ~38/(4 * 3.7) ~ 2.6A.
So current through each cell would be approx 2.6A. Maybe 3.5A at the very most.
I just dropped the dime on the wife about the purchase of the MH20GT and now you're wanting to have my cojones modified.
If 2s2p, then the driver is actually a boost driver, right? Would the 3.5A cover the overhead amperage needed?
If it is a boost driver, I wonder if acebeam determined that they can build it for 2s2p that is more efficient than a buck driver for 4 cells in series.
Edit: If like you said, 15Vf is needed for max output, then maybe it is a buck/boost driver?
That's one way to make a parrot quack! oo:
Nice pair ven!
You do not have long resisted the temptation ...[emoji6]
