Hi -
Been reading quite a lot, trying to avoid the inevitable questions answerable by search.
Been diving for a while now - I dive mostly in Eastern WA in the US, and make it to the Puget Sound whenever possible. This means that 4 meters of viz is a good day. So - as my first can light I was thinking of shamelessly copying Packhorse's 4xXRE monster.
So I've put together this parts list:
# Item Source Notes
4 CREE Q5 LED DX SKU11022
4 aspheric lenses - 21x7.3mm DX SKU 13903 - 10 pack
1 Mag Light host old stock
12" PVC for spacers Home Depot ID 16mm - 1/2" SCH40
1 tube thermal glue DX SKU 4579
6 Li-ion batts - protected DX SKU 20392 - 2 pack
PVC for canister Home Depot 3"
2 Latches for Canister McMaster Carr PN 1794A43
Canister O ring McMaster Carr 3-3.5"x1/4" buna n PN 9452K237 - 5 pack
Hose Clamps to secure can Home Depot
1 Driver - 2.8A KAIdomain SKU S005296
2 cable glands McMaster Carr PN 6907K12
10' hookup cable - silicone jacketed Home Depot 16gauge 2wire
power connector old stock from auto bucket
AL for heatsink old stock
thermal paste DX SKU 4593
1 reed switch Mouser M PN 876-KSK-1A81-0510
1 magnet for reed switch McMaster Carr PN 5902K53
1 MOSFET for switch Mouser M PN 512-FDP80N06
1 tube epoxy old stock
3 battery charger DX SKU 4151 - 2x charger
Mag bezel/lens Oring McMaster Carr PN 9262K207 - NBR 70 48mmIDx2MM 25pack
Tail cap Oring McMaster Carr PN 9452K88 - NBR 70 124 - 100pack
1 lens - 52mm for host DX SKU 25231 - 5 pack
1 lens - 50.8mm for step DX SKU 10647 - 10 pack
Sorry about the formatting, copied from spreadsheet.
Was going to build a canister out of 3" PVC with oven flattened sections for top and bottom. Reed switch driving a MOSFET driving the Kaidomain cheapo driver, for now.
I don't have a lathe, but I do have some 1/2 inch aluminum plate I think I can get a usable heat sink out of. I was going to glue the lens spacer PVC to a backer board and turn the sections down in a drill press. Tedious certainly, but I've got more time than money - and often more time than brains.
Any thoughts on this list - either parts or suppliers? I've got a few other things I need to flesh out the Mouser order. Old Stock means I've got it laying around.
One thing I'm not too familiar with is battery packs - was going to make an easy to disassemble 3S2P pack for the driver, hoping for ~5 hours burn time. Would charge each battery separately to try and keep them balanced. Again, more time than money. I'll probably buy parts to build 2 as my dive buddy could also use a can light - I'll charge him for my time... :)
Does this seem about right?
Thanks in advance.
Will
# Item Source Notes
Thanks in advance.
Will
