New CCT/CRI Specified Rebels! Do they use Lumaric Phosphors?
Gryloc
Cincinnati, Ohio & North Lewisburg, Ohio
Seeing how high CRI LEDs are becoming more popular at the CPF, and knowing how picky some of us can be with choosing the tints of our white LEDs, I am surprised that no-one else posted any threads about this. Here is the link to the products page:
http://www.philipslumileds.com/products/luxeon-rebel-white/
In order to see the press release, just navigate to the home page and check out the "What's New".
So, here we have the use of what appears to be special phosphors in order to obtain a more exact tint that falls on or near the black body line. I read through some documents on Lumiled's website, as well as to some posts on the CPF, and I learned that previously, only the warm white Rebels used Lumiled's Lumiramic phosphor technology. If you look at some of the pictures of these newer Rebels in the datasheets, the phosphors look very unique. Since these newer Rebels are CCT specific, then does that mean that all of them use the new Lumiramic phosphor technology? If so, I think that only the LXML-PW51 emitter either does not, as you will find it has slightly different "Relative light output vs. thermal pad temperature" curve. I assume this is because the use of different phosphors than the rest (it has slightly worse performance like the old TFFC Rebels). Regardless, the newer Rebels perform better than the older TFFC Rebels when it comes to light output vs temperature, and forward voltage versus forward current.
I wonder if the die image will have such strong artifacts as the original TFFC dies (due to the apparent grid of vias). If the new phosphor is thicker and/or diffuses the light a bit more, maybe those dark spots from the vias, and the resultant artifacts will dissapear!
Even though these emitters are not yet available, this is great news for those in the lighting industry (especially residential). This is also those who desire the color temperature (and as a result, a perfect tint) without sacrificing CRI as much. With these, hopefully we will not get the usual ugly variations that we have learned to cope with (such as the ugly urine-green, blue, and pink tints).
These newer Rebels have the same super low forward voltages as the once new Rebel ES. For example, the typical Vf at 350mA is only 3.0V. This is wonderful considering some XR-E and K2 emitters have relatively high Vfs (some similar to the old Luxeon K2s: eek).
BTW, a bit off topic: I was lucky enough to purchase a bunch of 0200 TFFC K2s a while back, and these actually have the same Vf range as these new Rebels (in my careful testing during burn-in). I feel so lucky to have a average Vf of 3.08V @ 350mA, 3.23V @ 700mA, 3.33V @ 1A, 3.45V at 1.5A and even only 3.54V @ 2A. It makes electrical design a bit easier at times!
So, even though many have forgotten about Lumileds, it is still interesting how they have improved their Rebel LED line (both for whites and colors -namely amber).
Cheers,
-Tony
This looks like terrific news. What I don't get is why not transfer this tech in to a K2 package?
Or heck use this to create a new version of the Lux V. The old Lux V just couldn't handle the heat and the phosphor would degrade quickly.
The Lumiramic Phosphor touted better stability under high heat and better control of tint when it was announced I figured using it with TFFC technologies they'd be able to create one hell of a multi-die emitter.
Side note: I wish they would update the older Lux footprints so we'd have easier emitter upgrades.
Wow! The 3000K one looks interesting. 90 CRI, that's pretty nice. Plus, the center shouldn't be blue compared to the edges.
GenX may be the reason why they don't want to transfer this to the K2 package. I wonder if this means that GenX will be out soon since clearly they already can produce the dies (Arcmania got some samples in a K2 package) and this might be the phosphor they're going to use.
Just a note about Vf. The cyan and white Rebels (not ES) I recieved a week ago were all C bin but the red ones were D bin (weird). The cyan and white rebels had a Vf of about 3V at 700ma. Using the spec sheet's typical 180 lumens at 700ma, that's 85 lumens per watt at 700ma. Not bad for a neutral white emitter!
I thought I would share some information I received from Future Electronics. After asking about a different product, I asked how soon these newer Rebels will be in stock to order in small quantities. The person I spoke to said that they are currently on order, and Future should have them for sale by either late August, or early September. For example, for the 4000K LXM3-PW51 part, they have a million on order and should be in stock by late August. I believe some of the other new parts may come in at a later time. If these parts will not be in by this time, Future has orders for additional reels on every month past (for all part numbers).
This is the best translation I received, as I do not procure electronic parts much, and I am not totally sure how Future's and Lumiled's system works.
-Tony
After looking at the list I'm disappointed they have no high CRI, high CCT parts. It seems no LED maker is catering to that market at all. While high CRI in 2700K to 4000K is all good and well, that isn't the entire lighting market. There's a huge market in "sunlight spectrum" type lighting with high CRI and a CCT in the 5500K area.
http://www.philipslumileds.com/pdfs/DS63.pdf
Datasheet for these new rebels has a nice big picture of the new phosphor. Strange texture, looks kinda "spunky" :green:
Reminds me of a seoul phosphor but more obvious; it doesn't kind of fade out to clear, but it is globbed on there..
What if that was a "handmade" prototype and the actual final product has a better application of phosphor? might beat projected specs
Seems more like a rendering than the real thing. The crystallization is very strange. I think the best of the bunch is the LXM3-PW51.
I think that's just the dome distorting the phosphor.
Jeff,
Future does not have them in stock for small quantity orders yet. They supposed to be ready to order by the end of August or early September. If you add one of the parts to the shopping cart, you will see a little star that shows up next to the item meaning the current part is on back order due to the current inventory level. I tried already after seeing the announcement... :tinfoil:
It is strange that they show a quantity in reserve stock, though.
-Tony
Nuts!
Thanks for the info, Grylok! Yes, I agree that it is odd that Future would show stock level numbers and not really have any. You are a good man for speaking up.
I was making my LED shopping list, checking it twice, and now I have to wait.
Surely there are 12 other things for me to do anyway...
Jeff O.
