MrGman
- Joined
- Feb 6, 2007
- Messages
- 1,777
Re: (More Pics) BeamShots Comparison of Malkoff Triple Drop-M60/M60F +more Flashlight
Yes I have, it does the same thing on the M60 that it does on the triple, makes for a nice wide hot spot in the horizontal axis with smooth even spill into the vertical axis. So it will smooth out the hot spot by spreading it out more evenly horizontally, yet be bright in that narrow central area vertically. Whereas the Flood model is a semi wide beam in a circular pattern.
The whole point of this specific filter is to just spread out the beam in one axis be it horizontal or vertical to see what you need to see. Since we live mostly in a a horizontal plane, if you wanted to see everything across the "landscape" in one shot and not waste putting a lot of light up into the trees or down at your feet, this is the filter.
On the other hand, if you were looking up a ladder or a narrow stairwell and wanted to see the entire vertical path without wasting a lot of light sideways, this would be great, simply rotate the flashlight 90 degrees.
This type of filter might be very useful for bike lights to light up along the street and see whats around a corner as one example of a specific use.
I could see it as a flip up filter accessory for the maglight or for the M60 on a Sure Fire or other light of similar configuration.
The 2 samples Gene gave me were precut to fit inside the maglight bezel. I placed them in front of the M60 in a SureFire host but don't want to cut it down to that size as I have more research to do, and kind of like it for the Maglight with the triple drop.
I am asking Gene if the company makes any that is just a little less wide and so narrow in the opposite axis. In other words not such a skinny wide rectangular pattern. Something more along the ration of 2:1 like the movie screen patterns in the theaters.
But the more I look at this the more I like it.
MrGman, have you tried out Gene's diffusion material on the M60? Be nice to compare it to M60F.
Bill
