Sold/Expired NEW - Delrin Tailstand Extension for Surefire Z41 and G2/G3 tailcaps
Moddoo
Minnesota
I'm going to bore some of these deeper to match the button height and to allow a tighter fit on the Z58/Z59.
I'll list them here tomorrow for you guys.
:thumbsup:
gswitter
California
Mine arrived yesterday.
I was most interested in trying them on a Z59 (U2), and I'm satisfied with it. Every shroud I've tried with on a Surefire tailcap has been a little awkward due to the long travel of the Surefire switches. That's still true of this extension, but the wider opening around the button helps. I imagine it will work well with the shorter travel of a McClicky. This shroud is definitely usable. It's very secure on the tailcap, and does make for good grip.
I have no experience machining delrin, so I don't know if a mm or two could be taken off the diameter without reducing it's rigidity. A little more narrow extension would be my preference, but I wonder if that might reduce the size of the opening around the button, and make it a little more awkward to use.
Overall, nice work. I've tried a scalloped Leaf, RPM, and another no-name, tail-standing C-series compatible tailcap, and at least for the U2, I prefer the stock Z59 + this extension.
Kindle
Buckeyeland
Received a Z41 shroud with the clip today.
I just wanted to verify about how much force is necessary to install these on a G2 tail cap.
It looks like I'm going to have to place a board or something similar over the shroud & then use a hammer to pound it into place (or preferably a rawhide/rubber hammer if I had one handy).
Does that sound about right?
FroggyTaco
Central Ca
I think you are supposed to place the shroud in a plastic baggie & place it in boiling water for a few minutes so it is easier to put on the light. Once it cools it's on tight!
Moddoo
Minnesota
Thanks FT.
Yes, some tailcaps are a bit larger diameter than others, thus it takes more force to get them on.
Boiling the shroud first will ease installation.
Kindle
Buckeyeland
Thanks FT.
Thanks for the assistance gentlemen!
Kindle
Buckeyeland
Update:
Popped the tailcap in the freezer overnight & placed the shroud in boiling water for 5 minutes or so (the clip made it easy to pluck out of the water, although I wouldn't recommend doing it bare handed)...
Placed on a flat surface with a bit of balsa over top & slid on with two taps of the hammer.
Thanks again!
Moddoo
Minnesota
We still have a few of these left to give your light a great barbell grip and tail standing function.
yifu
Australia
PP sent for another one of these as per PM! Unique Transaction ID # 66H31391GF186472X
TriChrome
Pennington, NJ
Since Yifu just bought one a couple weeks ago I assume they're still available. I'll take:
3B. BLASTED - AVAILABLE
Sent PayPal, Unique # XXXXX
180423L
