Silviron
Hi Ya'll-
Pardon me if this has already been discussed, I didn't see it with a quick search.
I just thought I'd pop in and give you the heads up on the new DOT regulations on shipping lithium batteries into and around the US.
http://www.ups.com/content/us/en/about/news/service_updates/battery.html
This just came up over at the endless-sphere electric vehicle website.
In spite of the regulation not being effective until OCT 1, one tof the members there was just informed that his thousand dollar battery pack that was shipped from China had been confiscated and would be destroyed as an illegal shipment of hazardous materials.
Lithium Battery Regulation Change
Service Update
Effective October 1, 2008, medium lithium batteries become fully regulated for air shipment in the U.S. Department of Transportation's (DOT) Hazardous Materials Regulations. Lithium batteries are considered a hazardous material because they can overheat and ignite in certain conditions and, once ignited, can be especially difficult to extinguish.
The new regulation will require packages containing medium lithium batteries, and offered for air transport, to be properly packaged, marked, and labeled as Hazardous Materials and accompanied by shipping papers. Otherwise, the shipment may be delayed, or significant U.S. DOT fines could apply. U.S. DOT has the ability to issue fines and penalties as high as $50,000 per violation for non-compliance.
Common examples of medium lithium batteries include:
* Power supplies for high-intensity, long-life portable lighting, such as diving lamps
* Some extended-life batteries for laptops
* Larger batteries for high-level video cameras (used by film and news crews)
* Long-life communications power supplies
These changes apply to shipments of loose medium lithium batteries as well as medium batteries contained inside of equipment, or packed with equipment.
Beginning October 1, 2008:
* Air shipments of medium lithium batteries must display the "Cargo Aircraft Only" label if the package exceeds 5 kg (11 pounds). UPS accepts hazardous materials only from shippers with a contract or agreement for such service.
* Ground shipments of medium lithium batteries must be marked as follows:
o "LITHIUM BATTERIES - FORBIDDEN FOR TRANSPORT ABOARD AIRCRAFT AND VESSEL."
o Text size for the above marking depends on the size of the package:
+ Gross weight of 30 kg (66 LB) or less - letters at least 6 mm (0.25 inch) high
+ Gross weight over 30 kg (66 LB) - letters at least 12 mm (0.5 inch) high
o If there are more than 12 batteries in a package, DOT requires an additional damage warning both on the package and in an accompanying document that would be affixed to the package in a resealable envelope. The DOT-required warning and document both advise handlers that the package contains lithium batteries and that certain safety measures are required if it is damaged.
For full information about these changes, shippers should review the applicable U.S. DOT Final Rule. Shippers may also contact the U.S. DOT Pipeline and Hazardous Materials Safety Administration's Hazmat Info-Line at 1-800-467-4922.
